Plex not recognizing deleted tv show
Installed unraid and got Plex(bin-hex plex) up and running. Everything seems to be working fine except for one thing.
Plex does not automatically detect if I delete a TV show. And the problem is only if I delete the entire folder.
Have it like this: Media/tv/
So if I in that folder for example delete the folder of a TV show it isn’t detected in Plex. I have to manually scan for it to be detected and get removed from the library.
If I delete just the movie files inside the TV show folder it is detected.
In Media I also have a movies folder. There it works like it should. I delete the entire folder with a movie and Plex detects it.
Any ideas what is causing this?
