Plex not seeing folders
Server Version#: .4145.1
Player Version#: NA
Plex running on a LXC with latest version of proxmox, and GPU share.
Folder from TrueNas Scale mounted using SSHFS on proxmox.
Inside the plex LXC i can see that folders are mounted correctly, I can list, touch and edit.
But the Plex Server seems not to see those folders.
It worked for over a year flawlessly, and after restarting my LSC it broke, with no reason and without any modifications.
Also, I will see if the Plex technical support will answer this, It seems not possible to ask for support with an email with a payed subscription ,
Going to bet its a permissions issue, otherwise can you post a missing folder and your server logs?
Problem solved, it was a Plex Update issue.
