Plex not stopping channels on tuner after done watching
PMS: 1.8.1.4139
Web Client: 3.14.1
Android: 6.3.4.1485 (0eaebc3e)
I have the HDHomeRun connect and all looks to be well, however when I start a Live feed everything seems to go well, until I am done and hit stop. It seems that Plex is not sending a command to the Connect to stop the stream on the tuner. After two plays I get errors that there is no available tuner and the Connect starts to reject requests for new channels. I have to physically reboot the Connect to be able to stream live TV again. I have tried setting straight stream and also tried setting it to auto transcode.
Aug 19, 2017 18:55:10.321 [0x7fb1edf85700] INFO - Plex Tuner Service v1.0.0.0 - unknown PC unknown - build: Aug 19, 2017 18:55:10.322 [0x7fb1edf85700] INFO - Linux version: 4.10.0-32-generic (#36-Ubuntu SMP Tue Aug 8 12:10:06 UTC 2017), language: en-US Aug 19, 2017 18:55:10.322 [0x7fb1edf85700] INFO - Processor Intel(R) Xeon(R) CPU X5355 @ 2.66GHz Aug 19, 2017 18:55:10.322 [0x7fb1edf85700] INFO - /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexme diaserver/Resources/Tuner/Shared 1.8.1.4139-c789b3fbb 32600 /waitmutex Aug 19, 2017 18:55:10.061 [0x7fb1f328a780] INFO - * broker_t::start... Aug 19, 2017 18:55:10.221 [0x7fb1f328a780] INFO - * device_manager_t::init. Aug 19, 2017 18:55:10.222 [0x7fb1f328a780] INFO - * device_manager_t::init. Initialize provider manager Aug 19, 2017 18:55:10.222 [0x7fb1f328a780] INFO - * device_manager_t::init. Initialize all device auxes Aug 19, 2017 18:55:10.222 [0x7fb1f328a780] INFO - * dvb_device_factory_t::get_aux_list Aug 19, 2017 18:55:10.222 [0x7fb1f328a780] INFO - * tvbutler_aux_t::init Aug 19, 2017 18:55:10.224 [0x7fb1f328a780] INFO - * web_server_t::start. Starting web server on port 32600 Aug 19, 2017 18:55:13.881 [0x7fb1e67fc700] INFO - * web_service_t::process_device_discovery Aug 19, 2017 18:55:13.883 [0x7fb1e67fc700] INFO - * device_reactor_t::get_device_list () Aug 19, 2017 18:55:13.883 [0x7fb1e67fc700] INFO - * dvb_device_factory_t::get_device_list () Aug 19, 2017 18:55:15.976 [0x7fb1e67fc700] INFO - * SAT2IP - discover_satip_servers(): no servers found Aug 19, 2017 18:55:16.392 [0x7fb1e67fc700] INFO - * v4l::DeviceGetList_impl. getting v4l device list Aug 19, 2017 18:55:16.398 [0x7fb1e67fc700] INFO - * onetv_factory::DeviceGetListEx >> Aug 19, 2017 18:55:16.399 [0x7fb1e67fc700] WARN - [W] onetv_factory::DeviceGetListEx. libusb_init returned an error -99
Aug 20, 2017 10:53:19.001 [0x7f2a9effd700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication. Aug 20, 2017 10:53:19.002 [0x7f2a9effd700] DEBUG - Auth: Came in with the master token, authorization succeeded. Aug 20, 2017 10:53:19.002 [0x7f2a97ffe700] DEBUG - Request: [127.0.0.1:59946 (Loopback)] PUT /video/:/transcode/session/a5c28478-1969-466b-97bc-c18c15811d64/14178f76-1d0e-4f9c-a31a-026ae57dc62f/progress?progress=-1.0&size=-22&remaining=-1&speed=0.9 (28 live) Signed-in Token (boboki) Aug 20, 2017 10:53:19.004 [0x7f2a9f7fe700] DEBUG - Completed: [127.0.0.1:59946] 206 PUT /video/:/transcode/session/a5c28478-1969-466b-97bc-c18c15811d64/14178f76-1d0e-4f9c-a31a-026ae57dc62f/progress?progress=-1.0&size=-22&remaining=-1&speed=0.9 (28 live) 2ms 326 bytes Aug 20, 2017 10:53:19.008 [0x7f2a9f7fe700] DEBUG - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication. Aug 20, 2017 10:53:19.008 [0x7f2a9f7fe700] DEBUG - Auth: authenticated user 1 as boboki Aug 20, 2017 10:53:19.008 [0x7f2a9f7fe700] DEBUG - Auth: Came in with a super-token, authorization succeeded. Aug 20, 2017 10:53:19.008 [0x7f2a837fe700] DEBUG - Request: [192.168.0.118:58991 (Subnet)] GET /status/sessions/background (27 live) TLS GZIP Signed-in Token (boboki) Aug 20, 2017 10:53:19.014 [0x7f2a9effd700] DEBUG - Completed: [192.168.0.118:58991] 200 GET /status/sessions/background (27 live) TLS GZIP 5ms 470 bytes (pipelined: 3) Aug 20, 2017 10:53:19.061 [0x7f2a89bfe700] WARN - [Transcoder] [mpegts @ 0x2c86fa0] PES packet size mismatch
Aug 20, 2017 10:54:01.278 [0x7f2a9effd700] DEBUG - Completed: [127.0.0.1:33678] 206 PUT /video/:/transcode/session/a5c28478-1969-466b-97bc-c18c15811d64/14178f76-1d0e-4f9c-a31a-026ae57dc62f/progress?progress=-1.0&size=-22&remaining=-1&speed=0.9 (27 live) 1ms 326 bytes
20170820-14:53:10 Tuner: tuner1 tuning 2.1 KDKA-HD (8vsb:539MHz-1) 20170820-14:53:10 Tuner: tuner1 streaming http to 192.168.0.160:59142
Logs show it completes, but the Connect never gets a stop command and the tuner just stays open.
Additionally, I cannot seem to play TV at all in the Web Client, just record.
Bumpity bump chump bump[!
Ker thumpity bumpity!
Bump chika bump bump…
Daily dump.
Well. I can’t answer your tuner question but the Web client does not have LiveTV yet. Only certain clients have it currently. Most likely coming but no timeline.
I had noticed the same about the tuner being locked after using Plex Live TV but I thought it was a tuner issue. However, now that I think about it it does not happen with the Channels app on the ATV4 so perhaps it is a Plex issue. I stopped using Plex for LiveTV at home so haven’t thought about it in a awhile.
Yeah, I tried it in the HDHomerun app and it works fine, and loaded emby real quick and it works fine there too, so pretty sure it’s a Plex issue, but I also use 3rd party stuff with it too so don’t want to outright point fingers.
Another day, another bumpitay!
Daily bump for JUSTICE!
More bumpage.
Few days later bump.
Try updating the firmware on your tuner itself I think I saw a similar thread with that being the fix. If not there is also a new server version now.
I have done that. It is in the latest currently.
Got some great news so far! Just upgraded to 1.8.2.4209 and my problem SO FAR seems like it had been corrected. I will let it run a few and then report back.
Yes, verified working and the latest 1.8.3.4235 this is also corrected.
