Plex not transcoding DTS to any other compatible format
Server Version#: 1.21.1.3876
Player Version#: 4.29.2
I have an LG TV and this TV can (due to missing licenses) not play DTS Audio.
It can Play every other normal format but not DTS.
Dobly Audio, AC3, EAC3, etc etc are all working.
Now I do have Movies which are 4K HEVC and just with DTS 5.1 (or DTS-HD 5.1) and Plex does not convert/transcode them. I turned off Video-Transcoding but I still want Audio trnacoding, but this does not work. When I try to play a Video with DTS just NO SOUND comes while the movie is playing.
Does anyone have the same problem and can help?
That is an older version but I think it has an option to disable DTS in the audio settings of the app which should then force it to transcode audio
Thanks I will try it.
