Server Version#: 1.14.1.5488
Player Version#: plex.tv./web
Hello I setup Plex on my Synology DS218+ and after selecting secured connections preferred every time i access plex.tv/web i get asked to allow once or always to access unsecured. Not sure what is wrong with my setup or what i am missing. In the past i was running PMS from my MAC and https worked.
thanks for any help
Noel
turned off the ‘redirect http to https’ option but i still get the plex screen to allow once or allow always because it cannot connect securely. I even restarted plex server. Any other ideas?
No because Plex is written to implicitly trust your home LAN as local .
We know that you’re using wired connections or encrypted wireless (unless you run your wifi unsecure).
PMS also knows that anything which is not Local is therefore remote. gets encrypyted.
I think there is a bit of a hang up here on seeing https in the URL. HTTPS is not required for the Plex/Web app and the server to exchange data securely. This is how Remote Access works. It looks like HTTP but isn’t.
