Server Version#: Synology 1.15.3.876
Player Version#:Synology 1.15.3.876
If Plex is set to Settings > Network > Secure Connections: Required, then connection to Plex from Synology Menu > Plex Media Server doesn’t work.
It attempts to open a connection to "http://192.168.85.100:32400/web/index.html
but http:// connections are rejected. If I manually change the URL to https://, I get a certificate error, and if I accept the certificate, I’m able to connect.
If Plex is set to require Secure Connections, the Plex Media Server menu choice should open to https:// and not http://
-Michael
