Plex on Mac 14.4.1 crashing
Player Version#: latest version
Plex is consistently crashing on the latest Mac OSX release with these errors:
Process: Plex [11389]
Path: /Applications/Plex.app/Contents/MacOS/Plex
Identifier: tv.plex.desktop
Version: 1.90.1 (1.90.1)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
OS Version: macOS 14.4.1 (23E224)
Report Version: 12
System Integrity Protection: enabled
Crashed Thread: 0
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace DYLD, Code 1 Library missing
Library not loaded: @rpath/libssl.3.dylib
Referenced from: <3044D84A-6523-3BAF-8867-B98BF81D2B03> /Applications/Plex.app/Contents/MacOS/Plex
Reason: tried: ‘/Applications/Plex.app/Contents/Frameworks/libssl.3.dylib’ (mmap(size=0x1792F0) failed with errno=1), ‘/Applications/Plex.app/Contents/Frameworks/libssl.3.dylib’ (mmap(size=0x1792F0) failed with errno=1), ‘/usr/lib/libssl.3.dylib’ (no such file, not in dyld cache)
(terminated at launch; ignore backtrace)
It doesn’t sound quite like the problem I was having with Plex Player crashing on OS14.5 which was also associated with Safari and Chrome crashing. My problem was solved on the Apple Discussion forum by deleting the file listed below. No need to logout or restart.
carfax
carfax
User level:Level 1
34 points
Posted on May 24, 2024 9:42 AM
Slightly easier fix:
I had essentially the same problem. Web pages making every browser crash.
System settings crashing on Accessibility-> Spoken Content and Live Speech
I went into preferences and found that the only recently changed pref was:
com.apple.SpeakSelection.plist
So I deleted that and System Settings Accessibility-> Spoken Content and Live Speech immediately began to work again and web pages began to display without crashing.
View in context
