PLEX on PR2100 is unreachable
Server Version#:1.14.0.5470-9d51fdfaa
Player Version#:Latest for PS4, Vizio TV
HI - is there “clean up” tool for the PR2100 App uninstall process? My network config changed (e.g., external IP address from ISP), and now all my clients think that PLEX on PR2100 is unreachable. Even after I uninstalled and reinstalled PLEX on the PR2100.
I know the uninstall was not thorough since after the uninstall/reinstall, it came back up with all my libraries intact, playlists, everything. And the bad IP address.
So in detail:
  • At one point the PLEX server had two IP addresses associated with it: the Local/LAN one in the 192.168.* range, and the external one used to connect to the outside world (e.g., PLEX servers). That external address changed.
  • It has not helped for me to turn off remote access. Turn it back on again. Whatever. The Clients all seem to see the old external IP address and therefore cannot connect to PLEX on PR2100 since that external IP address is not longer valid
  • PLEX server is fine, from the point of view of the web client from the PC
  • PLEX client on Vizio TV and PS4 can see it, but think it is unreachable.
  • Renamed the PLEX Media Server "friendly name", and Clients tracks that name change, but still unreachable
  • Force changed the IP Address of the server - no benefit (the clients followed it but can’t connect)
  • I logged in using SSHD, but nothing obvious.
Is there a config file I need to flush out?
Dean
Here is a log ZIP of the activity at the time of the failurePlex Media Server Logs_2018-12-07_19-58-34.zip (1.8 MB)
