Plex on qnap server few things wrong or missing
one ( user account qnap uses admin account even if disabled, probem with this is any hacker do same, gain access to files del them steel them,
2 ( user files should be compaired to them on plex server if one found be damage should be replaced, now i understand copy right laws as long as 1) person owns the meda dose not share out the meda to plubic to repair said music or movie would not break any laws,
3) with user consent plex could use part of what all people have to share out to others, but we want something in return one inshure vpn connetion to plex is set up and compeatly working, onbouth ends, two u track what we like so say i watch sifi movies down load them that dosent have copy right restictions to it, there ton moveis free get , there for u expland our colllection with in framwork of law u inshure files not stolen or removed, and u get to use our servers to help others on moives,.. also to provent del files from any work station unless that work station is added to securty list and to inshure this not hack connection changes securty key every 45 mins, and it also montors any ip address dose not have mac address and blocks them, any out side servers workstations are also auto blocked, to gain remote access u insurt ubs sick will copy vpn files and all information, with log in, u install it on labtop will auto install u have access to your data, these things so simple to do, and in fack u use same thing to del the files must have master usb key to del them , all other access other then adding to any all exe or files can run be block by default,
these things would be so simple to do, and make systems much more secure then as they are, remote access at any lev should be blocked,
plex can install there own account with a rotating password of 256 bit wich change every 24 hrs, there for only throw usb key wich would add a 2ed account have remote access to play update meda but cant del files, hope u consider these things
Well, as you say, it’s QNAP, and not Plex, and the way it works for all Apps on a QNAP
So you are asking Plex to have a working copy of all movies, shows etc. in all versions avail, and replace on the fly if your system fails?
Sorry, but we are not a backup company, so you should look elsewhere for a solution
Also note:
  • We do NOT want to know what you have on your system
  • We do NOT want access to your system
Again, we do not have a service like that, nor do we want to have.
Instead, you can use our free online Ad supported catalogs:
https://watch.plex.tv/
All in all, you sadly missed the concept of what Plex is
plex catlogs all on server they have full list now to include hash code of file os all needed, two plex need copy nothing as our servers are all ready on there servers anyway, or did u all not know this, plex sees all our servers, and they know file by file what we have, so what i propose is not anything that not going on now, , now if u all did not know this plex not only sees whats on our servers as they being updated they also stored in db u did know this right, so again what i ask is nothing plex not doing, but, saying this for plex also down load the hash code to inshure files are not damage i dont think to much to ask , and to proteck files from theft should also be on plex more so if it stolen throw plex, to note qnap some one hack qnap server got access to my account and try download rasomware, what they did not know was my network was beaking the file as was made to do, it to broken the raid, so rasomware not be installed do safe gards i got in place, u know what fine is to file share, if some one access your server file share files u lieble for it unless u prove was throw qnap or plex that is law by way, and plex know this as well as i do, why i ask for securty that be next impossable get around next impossable some one wants something they take it , regadless what is done for most part they safe ,
and by way i paid for life time for plex wish i never did as keeps crashing and another fack i down load anything off your servers, little code change in plex software, in fack some one writen the code do this i not installed it , found it interesting
Above is simply not true!
When PMS (Plex Media Server) scans your medias, the outcome is stored in the local PMS, and NOT with us
Ref: https://www.plex.tv/about/privacy-legal/
That is simply not possible!
Our Online catalogs only allow streaming access, and not download
and i know full well what plex is in fack i trace all there severs do,
i help microsoft with code sence dos, i did things they said was impossable
i know full well what plex is as much like grace note, but plex should be aware theft files proving that a plex account was used is leagle probem they done want get in to, give u idea my libary 400k songs 20k movies,
Closing this thread, since it’s clearly leading to nowhere
