Server Version#:1.22.2.4282
Player Version#:5.13.0
Hello everyone,
I have my Plex running on a Raspberry Pi 4 8 gb ram and its inside a Docker container. My tv is Samsung Q90T and it doesn’t support DTS audio so what I want is that plex only transcodes the audio. Both my raspberry and tv are connected to router with a lan cable. When I play a AC3 audio movie it plays without any problem but when I try to play a dts media it tries to transcode both video and audio. I have direct play enabled but when I check the logs it says direct play is disabled. When I enable option for disable video stream transcode and try to run a dts media it directly fails and says unexpected playback issue. So where can be my problem if you guys can help me I really appreciate it. Plex Media Server Logs_2021-04-20_07-12-05.zip (4.3 MB)
[Transcode] Found session GUID of ekncs212ybfkrctp53e1eh6o in session start.
[Transcode] TranscodeUniversalRequest: using augmented profile Generic
[Transcode] We’re going to try to auto-select an audio stream for account 1.
[Transcode] Selecting best audio stream for part ID 48330 (autoselect: 1 language: en)
[Transcode] We’re going to try to auto-select a subtitle.
[Transcode] Subtitles: Found a candidate subtitle language [eng] for a foreign film
[Transcode] Subtitles: Found a candidate subtitle that matches our forced / language preference. [0]. Reason [Prefer sidecar]
[Transcode] Audio Stream: 61670, Subtitle Stream: 61688
[Transcode] Scaled up video bitrate to 40467Kbps based on 1.500000x fudge factor.
[Transcode] MDE: Selected protocol hls; container: mpegts
[Transcode] MDE: analyzing media item 48302
[Transcode] MDE: 12 Monkeys (1995): Direct Play is disabled
[Transcode] MDE: 12 Monkeys (1995): media must be transcoded in order to use the hls protocol
[Transcode] MDE: 12 Monkeys (1995): selected subtitle cannot be converted to a compatible format, burning into video stream
[Transcode] MDE: 12 Monkeys (1995): Direct Streaming is disabled, so video stream will be transcoded
[Transcode] MDE: 12 Monkeys (1995): no remuxable profile found, so video stream will be transcoded
[Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
[Transcode] MDE: 12 Monkeys (1995): Audio Direct Streaming is disabled, so video’s audio stream will be transcoded
[Transcode] MDE: Cannot direct stream audio stream due to profile or setting limitations
[Transcode] MDE: 12 Monkeys (1995): selected media 0 / 48302
