Plex on RN312 (OS6 v6.10.08) only accessing files in top level folder?
Server Version#: 4.100.1
Player Version#: 1.65.1.3596-7b1f6d97
I am new to Plex. I have organized my TV, Movie, and video files per the instructions found on the Plex Support website (See attached screenshot).
The problem I’m having is that Plex is displaying the files contained in the Barry (2018) sub-folder as the contents of all the sub-folders in the US Mysteries folder. NOTE: This is happening with all my category folders.
As an example, In the Leverage (2008) sub-folder, the files contained in Season 01 are correctly saved on the server.
However, Plex displays the files located in the Barry (2008) folder
Any help you can provide will be greatly appreciated.
Thank you.
Which folder are you adding to the Plex TV Shows library?
Plex does not support subfolders between the folder added to the library and the main show folder.
So, using Leverage as an example, you would need to add US Mysteries to the TV Show library, not TV Shows or Adults TV.
Thank you, @FordGuy61 . I’ll give that a try.
