Need some help fixing duplicate/mismatched files
EDIT - Solved: this was the cause of the problem: “…if you add /TV Shows to your Plex TV Show library, then you cannot have subfolders such as ~Documentaries underneath”.
After resolving that, things are now displaying correctly. Thanks to FordGuy61 for spotting that!
Server Version#: 1.24.5.5173 (Mac)
Player Version#: 1.38.0.2734 (Windows)
I’m finding that several of my locally-stored TV shows aren’t showing up in the ‘TV Shows’ view. They show up in folder view, but when check the thumbnail/title/description, the info is from a different show. And if I do ‘Get Info’ on an episode, I often find multiple file paths listed.
Here’s an example of the BBC shows Planet Earth and Big Cats, along with what I’ve done to try to fix them:
  • Moved the folders for both shows out of those scanned by Plex
  • Updated the library
  • Confirmed both shows were gone from folder view and didn’t show when using the search box
  • Emptied the trash
  • Cleaned the bundles
  • Made certain that the two folders and their contents were named properly
  • Dragged Planet Earth back into the correct folder, updated the library and confirmed that it showed up in folder view
  • Checked thumbnails/titles/descriptions of each file: all were correct
  • Did ‘Get Info’ on each episode: all were pointing to the correct files
  • Dragged Big Cats back into the correct folder, updated the library and confirmed that it showed up in folder view
  • Checked thumbnails/titles/descriptions of each file: the three episodes incorrectly show this info for the first three episodes of Planet Earth
  • Did ‘Get Info’ on each episode: each file showed two entries - the incorrect Planet Earth episode at the top and the correct Big Cats one below it (screenshot).
Any ideas how I can resolve this?
Which folder did you add to the TV library, TV or ~Documentaries?
Given the structure shown in the screenshot, it should be ~Documentaries.
Plex does not support subfolders like ~Documentaries if the TV Show library is pointed at /Volumes/Media/TV.
Edit: Also use two digits for the episode number. Planet Earth is s01e1. Should be s01e01.
As in, it doesn’t support subfolders with a ‘~’ character? Or it doesn’t support subfolders below the folder added to the library unless they’re TV show folders containing ‘Season 01’, ‘Season 02’, etc.?
Good catch - I’ll fix that!
AFAIK, ~ & similar characters are OK.
What I was trying to say (albeit not very clearly), was that if you add /TV Shows to your Plex TV Show library, then you cannot have subfolders such as ~Documentaries underneath.
However, it is certainly OK to add ~Documentaries to a TV Show library, as it is the folder containing the TV show files.
Examples:
Not supported:
/TV Shows  <-- Folder added to Plex Library
.../~Documentaries  <-- Not supported
....../Planet Earth
Supported:
/TV Shows
.../~Documentaries <-- Folder added to Plex Library
....../Planet Earth
....../Planet Earth
Another thread along similar lines:
That was the problem: once I resolved that, things are displaying correctly. Well spotted and thanks!
