Hi All,
Resent i did test a movie. But the App on my Samsung TV crashed. On my Plex player and Apple tv the file worked fine. I did checked the encode info of the file.
Media
Video Resolution 1080p
Duur 1:50:18
Bitrate 10312 kbps
Width 1920
Height 800
Aspect Ratio 2.35
Container MKV
Video Frame Rate 24p
Audio Profile dts
Video Profile high
Deel
Duur 1:50:18
File --------.mkv
Size 7.95 GB
Audio Profile dts
Container MKV
Video Profile high
Codec H264
Bitrate 8776 kbps
Bit Depth 8
Chroma Location left
Chroma Subsampling 4:2:0
Frame Rate 23.976 fps
Height 800
Level 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1920
Codec DCA
Kanalen 5.1
Bitrate 1536 kbps
I think i found the problem why it did not play on my Plex TV app. Video frame is 24P instead of PAL. All other setting are most likey the same… Any idea how to solve this problem? Of do i need to encoder the file to standard PAL format.
Maxx
