Samsung Frame TV - Completely Unusable
Hello, for about a month now I have been unable to view Plex content on my 2022 Samsung Frame TV using the Plex App. The content will load a black screen, with a seekbar, but no picture - it will then throw an error “Playback Error - An Unexpected playback problem occurred”. This content is Direct Playing on video and audio.
I had used this successfully for over a year, and it has just stopped working. this is a main TV in my house, and I need some guidance on how to get this working.
I have tried:
“re-installing” plex
deleting the application, redownloading, re-signing in.
I have tried allowing insecure connections. The server is on the same network as this TV.
On the plex dash, it even says my content is playing, and the connection is secure - until the error ends the stream.
Server Version#: 4.148.0
Client Version: 5.92.0
Platform Version: 6.5
in my log overlay Im getting the following:
07/08/2025 18:25:21:490 [(name):cylnb3xz1egy02fe3|8kcj7b] ERROR [AVPlay (IDLE)] onAVPlayError: PLAYER_ERROR_CONNECTION_FAILED
07/08/2025 18:25:21:513 ((name):cyinb3xz1egy02fe3|8kcj7b] INFO [PlaybackSessionController) playback state changed to: stopped
07/08/2025 18:25:21:555 ((name):cyinb3xzlegy02fe318kcj7b] ERROR Playback error occurred. Reason: Buffering Timeout, Player took too long buffering, stopping playback
07/08/2025 18:25:21:569 ((name):cyinb3xz1egy02fe318kcj7b] WARN [PlaybackSessionController] could not retry, reporting error
07/08/2025 18:25:21:599 ((name):cyinb3xzlegy02fe3|8kcj7b] INFO Opening modal: ActionsModal
07/08/2025 18:25:21:679 ((name):cylnb3xz1egy02fe318kcj7b] INFO Opened modal: ActionsModal
@BigWheel @Craig_Holliday - do either of y’all know anyone over at Plex who can look into this and give me a hand? Its my main tv so this is a critical problem for my setup.
I am having the same issue on 2 Samsung Frame TV’s seemingly overnight.
In the console I am seeing this error:
[Req#17a97] [Plex for Samsung] [ZENTRON8000:rk9xvermu09uafflu162j9kw] Playback error occurred. Reason: FailedToSetupOrCreatePlayer, Failed to create or setup player! Message: Cannot read property ‘continuity’ of undefined
I don’t think this will change things but there was an update yesterday. just wanted to check if still having issue with 5.93.1
This isn’t the server version it’s the web. There should be another general section a few down below the server name.
Also can you get the full logs so i can add to report. https://support.plex.tv/articles/216955788-logging-for-smart-tvs-tivo/
Server Version#:4.146.0
Player Version#:5.93.1
Seemingly overnight, both Frame TV’s in my house get error ‘Playback Error An unexpected playback problem occurred’. on anything I try to play.
In the server console I see this error:
I have set both server and client to allow insecure connections.
I have reinstalled the app on the TV and have tried multiple different versions of PMS software as well.
I have also turned off ‘Quality Suggestions’ on the client.
Nothing has helped so far.
Can you get the full logs so i can add to report. https://support.plex.tv/articles/216955788-logging-for-smart-tvs-tivo/
Plex Media Server Logs_2025-07-12_01-52-00.zip (3.0 MB)
Logs attached.
I also starting having this issue with a Samsung TV. Unable to watch anything with Plex.
Jul 12, 2025 19:14:41.012 [140018455583544] WARN - [Req#262] [Plex for Samsung] [xx:xxxx] [PlaybackSessionController] failed to open playback! Cannot read property 'continuity' of undefined
Jul 12, 2025 19:14:41.012 [140018455583544] ERROR - [Req#262] [Plex for Samsung] [xx:xxxx] Playback error occurred. Reason: FailedToSetupOrCreatePlayer, Failed to create or setup player! Message: Cannot read property 'continuity' of undefined
Jul 12, 2025 19:14:41.012 [140018455583544] WARN - [Req#262] [Plex for Samsung] [xx:xxxx] [PlaybackSessionController] could not retry, reporting error
Same issue on a Samsung TV from 2021 with the error “ERROR Playback error occurred. Reason: FailedToSetupOrCreatePlayer, Failed to create or setup player! Message: Cannot read property ‘continuity’ of undefined”
Worked flawlessly before I went on vacation, came home to an app that can’t play anything.
Why no support on this issue?
Same issue here, different model of TV, but same OS
Samsung TV and Tinzen 5.5
Samsung TV specs:
“AVPlay version”: “4.0”,
“Tizen version”: 5.5,
“Package version”: “5.64.1”,
“Model”: “UA32T5300ASXNZ”
Hi all. Looking into this issue now, thanks for the logs.
Looking at bug report this looks fix and should be in 5.93.2. I don’t know exactly when it will get released but should be soon
Discovered only this problem today and I was surprised that suddenly nothing is working in my Samsung TV.
Now im waiting for the new plex update. :frowning:
Same issue on my Samsung The Freestyle projector. I’ve been watching this thread for three days now. Like it if you have the same problem, so as not to clutter the thread with messages.
This issue is really weird, now i tried again and I can play the videos that cannot be played earlier. I did no changes/update on tv client and on local plex server, which makes me question if the tv client or local plex server need to check plex’ cloud server?
I just tried again on one of my TVs and it’s working for me now too. Very strange.
This should be fixed now in 5.93.2
Hi @Moussa I just tried this again and am still having the same problem as my original post at the top of the thread. I am now running client version 5.93.2, and PMS Version 1.41.9.9961. I have sent you a DM with my logs.
@Moussa Thanks, that fixed the issue and error for me.
