I have a Sony Bravia TV (Android-based) and over the last month Plex might startup and work and sometimes would just end on startup. Over the last few days, it won’t run at all. I’ve tried clearing cache and clearing data. I’ve not tried an uninstall / re-install yet. I just installed an update on my Mac mini server.
Should I try rebooting the TV? Get an update on the TV?
At this point Plex is unusable and looking for what is the key issue (not sure how to get logs on the client) and how potentially to solve it. I’m technical so happy to debug.
I, too, am having this issue. soft reseting the device sometimes allows it to kick over to the UI from the loading screen. I am going to try reinstalling the app on the tv at some point.
(edit: I too have the Bravia 4k tv… also, i did uninstall and reinstall to good results on the initial opening of the application then subsequent opening of the app leads to the error.)
I seem to be having the same issue as well . Tried starting the app from the app store which worked oddly when the main menu wouldn’t launch the app. removing the app and installing it again seemed to temporarily resolve it for me.
Side note it seems to think that its not on the same local network as my Plex server and insists on converting my 4k content down because the network connection is too slow. then it says my Thread ripper doesn’t have enough power to convert 4k to 1080p 4Mbit
I’ve had the same luck with the cache clear, Or Clear Data and re-linking.
Took 4 goes tonight so I’m watching everything I can before changing to something else
Plex for Android ,BRAVIA 4K 2015 Current version (Not got the version to hand)
Server - 1.16.1.1291
Running Sony’s May security update Android 7 which was released this last week
I guess if i had a plex pass, I would be persisting 4 times also.
I did do a system update on the TV, its set to automatic.
I tried PLEX again and it crashed again. I quickly checked it this morning and can see it wants me to login … so not sure or why that happened.
I’ll do a full remove app from tv, config from server, shutdown the lot and start it all from fresh again. This will be the last time.
Just to be clear, I have two other android TV’s that run it fine, these are samsungs tho. Ipad’s, Phones, PCs, everything works except this Sony Bravia, which just so happens to be my main tv.
Some basic response from PLEX would be nice on this, as it stands, it just doesnt work and I cant justify wasting hours troubleshooting this.
i have same problem on my sony bravia 4k 55 inch, the app opens then crashes before the home screen displays. clearing the cache will get it to start once but maybe plays a video before crashing. all other devices work. definitely a app related issue. is there some way to roll back to stable version?
I have ben having the same problem. I tried all the suggestions but no fix. What I have tried is opening it through My Apps in Google Play. This works. And when I exit Plex I can open the app normally from my Home screen.
Same issue for me. Clearing cache and restarting the TV seems to intermittently fix it. But only maybe 3 out of 5 times. All other apps (Mobile, PC, Tesltra TV) work fine. Very frustrating.
