Plex on Synology DSM 7.2.2 fails to start
Server Version#: 1.41.3.9314
Synology DSM Version#: 7.2.2-72806 Update 2
As of today, and after nothing changed on my Synology 423+ NAS, Plex doesn’t run. I start the package and it falls over dead.
I upgraded to the latest version of DSM (I was a minor release behind) and then uninstalled Plex and manually reinstalled the latest version from plex.tv. The same thing happens. Not sure what I can try here.
Glad to post logs, how do I do that?
Unreal. Fixed. I had to clean uninstall, nuke the PlexMediaServer folder share, reinstall the latest version manually, then copy my library back into the newly recreated share. And then it just worked. Until I nuked the share, Plex wouldn’t even run.
I have no idea what happened. I’m going to leave this unresolved for a couple of days in case anyone can hazard a guess.
I actually thought tonight was the night I’d be switching to Jellyfin after 15 years of using Plex.
For future reference…
If Plex Media Server is running: Reporting issues with Plex Media Server
If Plex Media Server will not run: FAQ 1: Gaining access to the Plex logs or when PMS isn’t running / won’t start
Impossible to tell without log files. However, it reads like database corruption, which, if bad enough, can stop Plex Media Server from running.
It is relatively easy to determine if there is database corruption. Look in Plex Media Server.log (and rollovers .1.log to .5.log) for ERROR entries that mention the database is corrupt or malformed.
To repair database corruption, use the Plex DBRepair Utility. It is easier and more thorough than the manual steps in the Plex support article: Repair a Corrupt Database.
I agree it seems like database, but there were no entries in the logs later than November. Working now so I’ll mark resolved.
