Plex only seeing half a season
Server Version#:1.41.5.9522
Player Version#: Web
I’m having an issue with Plex only seeing SOME MKV files. Example is: I have a folder on my Synology drive for Demon Slayer. I own the first 4 seasons, and all files follow the same naming scheme. Example: Demon Slayer - SE1 - Ep1-4.
However, Plex is ONLY seeing SE1 - EP10-13 through Ep23-26. It’s not seeing the start of season 1, or any of the other seasons at all. I’ve tried changing the naming scheme, that did not help. I’ve rebuilt the library 3x now, and I even tried moving everything on the Synology drive to new folders, and then rebuilding the library from there, but Plex still only sees 17 episodes…
Usual suspects are bad file names or folder organization.
Would you mind sharing an example how your episodes are organized/named?
I already did mention that in the post. They all follow the same naming scheme.
Plex doesn’t support a SE##EP## schema.
So why does it see some episodes with that naming scheme? And what naming scheme does it accept?
Because it tries really, really hard to make sense of what it sees. Sometimes it can figure things out, until it doesn’t. That inconsistency in the face of unsupported naming schemes is why it’s best to stick to what’s officially supported. That way meaningful troubleshooting can be performed.
Plex supports “SxxEyy” where xx is the season (01 for example) and yy is the episode (02 for example). So you might end up with something like “Show Name - S01E02 - Episode Title.ext.” Though the episode title part is completely optional (as is the show name, technically, that’s only really needed in the folder name).
The linked document above goes into greater detail regarding folder organization and file naming.
I moved all of Season 1 into its own folder, like the document in the link said, and then renamed everything to Demon Slayer - SE1Epx-x and now Plex sees even less files than before. It now only sees a couple of episodes, and a bunch of my files now show a RED TRASHCAN on them.
Should be
Demon Slayer - s01eYY-eZZ
or
Demon Slayer - s01eYY-ZZ
e, not ep!!
Got it!. It was also the SE which should have just been S
