Plex Pass Perks WD discount
I used my code for a WD drive and it is the wrong item (my fault) and so I returned it and I am buying the correct item and now it gives me the same code on the Plex pass perks website and so I can’t get my proper discount.
http://www.plex.tv/plex-pass-perks
Can anyone help? Anyone not going to use their code that expires tomorrow?
Thanks!
Sure, I’m sending you a PM.
Shown at the bottom of the Plex Perks page.
“Plex Pass subscribers are eligible to fetch one code per promotion.”
I know. I had just used my code on the wrong thing and returned it and wanted to use a code for the right thing. All is well. Thanks.
I’m in the same boat :frowning: burned my discount code on an order I ended up returning.
Looking to place a new order but need a new discount code.
If you have a WD discount code you are not going to use can you PM it to me?
