I activated the WD promo code from Plex Pass, but when I try to use it, the WD site says the coupon code is no longer valid. From browsing the forums, it looks like this has happened before, but I haven’t found a solution.
What item are you trying to purchase. Keep in mind the code only works for things not already on sale.
I was trying to buy a WD Elements external hard drive. It looks like it is currently on sale. Thank you for the help.
