Plex pausing/stuttering on 4k stream
Server Version#: 1.19.1.2701
Player Version#: 4.22.3 - Chrome
com.plexapp.system.log (39.0 KB)
Log added:started movie at 6:54pm CST - 6:57pm CST. Movie paused ~1:14 in
Environment:
  • Plex box: AMD 6300 3core/6logical processors, 16GB memory, SSD, GTX 1050ti 4GB and 1GBPS wired
  • NAS: Synology DS212j 2x ST600VN0033 6TB in raid hybrid (SHR) pool 1, 1GBPS wired
Issue:
When I play a 4K movie (direct play) on the Plex it starts to stutter a little after a minute in then plays/pauses as it progresses throughout the movie. 1080p isn’t an issue whether trans-code or direct play. I first came across this issue trying to play the content over my first gen Google Wifi hub via Nvidia Shield (5ghz) so naturally I went to play directly on my Plex box to rule out some things but was surprised to see I can’t even play it directly on my Plex box via hard-wired! I did notice while monitoring the content playing directly on my Plex box that the Plex transcoder process goes to “terminate” around 30seconds or so before it pauses, however; it quickly spawns another one. Plex box CPU doesn’t go over 50%.
I’ve tried almost all transcoder combinations that I can think of :wink:
Cheers!
don’t use chrome to play 4k.
use the windows PMP or plex player.
plex for windows
https://www.plex.tv/media-server-downloads/#plex-app
Plex for Windows (NOT SERVER)
Windows 10 or later (64-bit only).
1.8.2.1192-89432618
April 17, 2020
or
PMP
Thanks. This fixed the issue where it can now play on my Plex box but when I try to stream it to my NVIDIA Shield TV via Google wifi(5ghz forced) it still pauses/stutters so this implies I have a bandwidth bottle neck? I have a long cat6 Ethernet cable coming in soon so I’ll hard-wire between my Shield and router then retest. I just don’t see how it could be a router bottleneck based on the monitoring I observed when I played it on my Plex box directly. It wasn’t pulling insane Mbps numbers. I guess time will tell. Thanks for everyone’s help.
I’ll update accordingly.
wifi can work, but depends on how congested it is and signal quality.
you might want to read @ Plex, 4k, transcoding, and you for a lot of background info on 4k with plex.
