Server Version#: 1.74.1.3913-9baac009
Got it thx
Got it thx
If you’re using Linux, why are you using CIFS (SMB)?
That’s totally nonsensical.
NFS is native to Linux (Synology is Linux based)
Install nfs-common on your linux system.
Enable NFS on the Synology
Now follow the tutorial / how-to here
You will find a lot of info about these type topics in “Linux Tips”
