Plex cannot read SMB or NFS mounted directory
Server Version#: 1.32.7.7621
I’ve mounted my NAS media to my host machine (Ubuntu 16) running Umbrel to ~/umbrel/data/storage/downloads folder since this is one of the locations mounted to the Umbrel container.
Plex is able to see the root mounted folder but is unable to see the contents. I’ve tried both NAS and SMB mounts with permissions set to 0777
What can I do so Plex will be able to see my mounted folder?
Update:
When setting up transmission complete and incomplete folder to the mounted path it instead created a local filesystem path with the same directory structure instead of reading and writing from the mounted path. This local filesystem path is invisible to the host until I unmount.
For reference here is the fstab config for both NFS and SMB
NFS: 192.168.5.160:/volume1/data /home/user/umbrel/data/storage/downloads/synology nfs nouser,rsize=8192,wsize=8192,atime,auto,rw,dev,exec,suid 0 0
SMB: //192.168.5.160/data /home/user/umbrel/data/storage/downloads/synology cifs rw,username=maurerbot,password=GasQKtBj&yUEJv.f4pZz,vers=2.0,iocharset=utf8,file_mode=0777,dir_mode=0777
Unless you also have Plex running as your username –
Get the mount points OUT OF YOUR HOME DIRECTORY :slight_smile:
Some reference reading for you
Please observe for my machine , NFS from my NAS to my workstation:
192.168.0.20:/vol/media     /glock/media       nfs defaults,sec=sys,rw,auto,async,x-systemd.after=network-online.target,nofail,bg 0 0
(I use the ‘network-online.target’ qualifier only because my network adapter is slow to start (thunderbolt 10 GbE adapter on a NUC8). Normal cases will not need this.
Supplemental:
You state Ubuntu 16 –
Hope you realize that we no longer support Ubuntu 16 (LTS support ended April 2021)
Oops! I’m on 22
I rebooted my host system and things seemed to work now. Not sure what changed because I rebooted several times before. I’m going to monitor the situation.
