Plex Player 1.6.3 nor 1.6.5 will open
Server Version#: 4.22.3
Player Version#: 1.6.5 or 1.6.3
Have no problem connecting to plex server web. Started in last week. Have uninstalled 1.6.5 reboot then reinstall 1.6.3 as well. Ran the vc_redist.x64.exe in installed plex directory as administrator and it tells me a newer version is installed. When you launch plex player via shortcut or run as admin it won’t launch. The application error log contains:
Fault bucket , type 0
Event Name: FaultTolerantHeap
Response: Not available
Cab Id: 0
Problem signature:
P1: Plex.exe
P2: 0.0.0.0
P3: 5E7E7947
P4: 16
P5:
P6:
P7:
P8:
P9:
P10:
\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER10EF.tmp.WERInternalMetadata.xml
These files may be available here:
\?\C:\ProgramData\Microsoft\Windows\WER\ReportQueue\NonCritical_Plex.exe_ef3a74c2bcd1bbd27cd48c59fd523df7013e8_00000000_33d2df9e-9918-4781-8b64-aa6189430c8a
Analysis symbol:
Rechecking for solution: 0
Report Id: 33d2df9e-9918-4781-8b64-aa6189430c8a
Report Status: 100
Hashed bucket:
Cab Guid: 0
I had the same issue with 1.6.3 and 1.6.5.
For me, it helped deleting the “Plex” application data folder:
You find the folder here:
C:\%userprofile%\AppData\Local\Plex
Afterwards, Plex did start again.
Deleting this folder will reset your Plex userprofile, so you will need to log into Plex again.
