I’ve read that there is now the feature to add your own custom artwork to Plex Playlists- but I can’t see this as an option for music playlists at all. How do I use this supposedly new feature.
Also, for months, I’ve had no artwork at all on any of my music playlists. All I have is a grey box and the name of the playlist and its length. The box is also oblong, not square as the music playlist boxes used to be. Nothing else. Just loads of boring grey boxes.
As an aside, that’s the version number of the Plex Web app. You can get the Server version farther down the Settings page:
That’s just an FYI, though. At this point, if you have that version of the web app, you have a server version that supports the feature too.
Do you have any script blocking extensions in your web browser? There have been odd instances where AdBlock prevented a tab in from appearing in the Edit Album dialog. If you have an ad blocker, try disabling it to see if the Poster page appears.
