Plex playlists use in poweramp
Right now i use the plex app to Play synced playlists. I really like the look of Poweramp and was wondering if I can use those sync playlists with the Poweramp app? Anyone ever try this or have any luck with it.
Plex’s playlist is stored internally in a database, it is not a standard m3u playlist file so other apps cannot see it, only the tracks themselves. Also, synced content is stored on a system folder on your device. You would need root access to see them.
You can export m3u playlists from Plex with the next (as in: ‘unreleased’) version of the WebTools plugin.
