I’ve got ripped TV episodes with both forced and full English subs, flagged properly, so the forced subs show up as forced on Plex.
Also, neither sub track is flagged as default, and while the forced subs once showed up as the first sub track on the list, I made the full subs #1, so they’d be picked by Plex regardless of the forced flag.
Since the Plex Dance so often fixes things, I’ve also switched my settings around, however to no avail.
My Languages settings:
Currently out of ideas, hoping someone can help.
Server Version#: 1.15.4.994
Player Version#: 3.83.2
Like I said, forced subs are flagged properly, and I want full subs, not forced, which is what Plex is selecting automatically.
And what @gary_parker was mentioning is how default-flagged subs work, not forced, and my forced subs are not flagged as default.
I’d start by using a supported folder structure. C:\Remuxes\Release\Season 6\done\Game of Thrones S06E03 Oathbreaker.mkv
will produce issues, sooner or later.
I am pretty confident that C:\TV Remuxes\Game of Thrones\Season 6\Game of Thrones S06E03 Oathbreaker.mkv
will work, if you point your Plex library to the folder C:\TV Remuxes
That makes literally no difference, since it grabbed all metadata properly and if I change my sub language to anything other than English it all selects them properly, but when I go back to English, it’ll prefer Forced over full subs.
Even then, I rearranged my folder structure, so everything’s clear, and the same problem occurs.
That’s a good point, maybe that’s what’s causing it.
However I tried setting the audio language to something other than English and Plex will still prefer English Forced subs over full, so I’m at a loss still
