Plex problem with 2 avi files?
Hi guys!
Don´t know if this is under right section. I´m running PMS on Synology, then using plex app for AppleTV,iPad,iPhone etc. When i´m trying to watch a movie which is splitted in 2 .avi files the Plexapp only plays the one named : mymovie.Cd01.avi.
If i want to watch mymovie.Cd02.avi i have to rename cd2 to cd1. Really strange????
If i go in to my media manager on synology it says that the movie is the right lenght, right cover etc. but when going in preferences for the movie it says the movie only contains cd01.
Would love to NOT using another program the create 1 file of 2. avi files since many movies in my library are splitted in 2 files.
Any solutions?
Regards Stefan
Stacked movie support is dependant on two things:
  • correct naming convention of te files (see the wiki)
  • support in the particular client application
    The latest version of the ATV2 software now has stacked file support, what version does it tell you that you are running in the ATV2 client preferences?
    I am not sure the iOS application has support, you may want to look in the iOS forum or wiki to check this (if it doesn’t you can join your files into one or wait to see if it is supported in the next version, it has been a requested feature).
