Hi there!
I keep having a recurring issue that started about 2 weeks ago where my server will just go offline at random times. Sometimes it will come back on in a few minutes, other times it will be hours. It happens suddenly without warning, I can’t think of anything I’ve been doing that would cause this. Please see my issue description and logs below.
Plex will be working perfectly, then all of a sudden it will go offline. From remote Plex app (for MacOS) it says “The server is unreachable,” going to localhost:32400 also shows it cannot connect to Plex (this is through a VPN connection). However, whatever is happening is not triggering a notification from Tautulli that the server is down or that remote access has been disabled. If I turn off Plex from Synology Package Center the “server is down” email immediately shows up in my inbox. I downloaded the logs from Tautulli which are attached below, they do not appear to have any interruption even while the server is unreachable. There was no interruption of internet service at my server location, I ran several speed tests from the Synology terminal and they matched speed tests I got from another device on the local network. The first log taken at 17:57 was while the server was unreachable. A few minutes later, at 18:03 the server inexplicably came back online and the second set of logs is from that time. Please let me know if verbose logs are needed. Server went down again at 18:53 with no warning or anything…see third log file attached.
Running on Synology DS218+, DSM 6.2.4-25556
Server Version#: 1.24.0.4930-6000
Player Version#: 1.33.0.2444-a220eae4
1757 Plex Media Server.log (2.3 MB)
1603 Plex Media Server.log (2.6 MB)
1853 Plex Media Server.log (3.2 MB)
Update 1: Realizing the Tuatulli logs are not as helpful as native Plex logs. I’ll attach some as soon as the server becomes available again. Also, after doing some further digging others have said this might be a networking issue. I have my NAS set as a static IP on my router and I have a custom port forward setup. If either of these could be causing issues I can troubleshoot as needed. Also, restarting the Plex package on Synology does not always fix the issue, however restarting the entire NAS has fixed it in the past. The zip attached below is from as soon as the server came back online after doing a package restart so I’m not sure if it will have the logs needed
Plex Media Server Logs_2021-08-22_00-51-36.zip (3.8 MB)
Update 2: Today the server has only been going down intermittently, a few minutes every couple of hours. Attaching more logs to see if they can help isolate the problem.
Plex Media Server Logs_2021-08-22_20-55-06.zip (5.9 MB)
