Hello
i have problem with Plex read S01E001 and S01E101 as one example if i finish watching S01E001 and mark it as i watch it the S01E101 mark as watch too and same happen for after All episodes
S01E002 with S01E102, ,
is there way to fix this ?
Thank you
dane22
April 28, 2020, 3:06pm
2
Not a help here, but merely a Q?
What show has +100 episodes in season 01?
Is the show “matched” properly or does it appear without metadata.
If it is matched, which metadata agent is used?
Please extract the content of the guid="...." property from the Plex XML info
– from both episodes 001 and 101
you want this right:
S01E001:
guid=“com.plexapp.agents.hama://anidb-13789/1/1?lang=en”
S01E100:
guid=“local://131504”
Precisely. Please ask the developer of the AniDB agent, because this is his agent. (3rd-party and unsupported)
Or change the match of the whole show to TheTVDB
https://www.thetvdb.com/series/black-clover
