divzero
September 23, 2019, 3:13am
1
Plex server 1.16.6.1592 on CentOS 7.
Web client on desktop Chrome and Firefox.
Server and client are in the same local subnet, which is added as a “LAN network”.
When the client accesses the server through app.plex.tv , the connection is “indirect” and all content is transcoded. My connection is fast enough to do direct play over the internet.
When the client access by https://server-ip :32400, the connection shows as “Nearby” and direct play is available.
So, I have two questions:
Why is the web client convinced the server is “indirect” when they’re in the same subnet?
How do I avoid transcoding for clients that can play direct over the internet?
ChuckPa
September 23, 2019, 6:01am
2
What LAN IP addresses are involved? Are they RFC 1918 compliant?
App.plex.tv will fail to “switch over” if DNS rebinding protection is active and blocks Private Domain plex.direct .
DEBUG logs (DEBUG on, VERBOSE off) captured immediate after recreating the problems (play a few seconds only is all that’s needed)
After stopping all playback,
Settings - Server - Troubleshooting - Download Logs.
Attach the ZIP
divzero
September 23, 2019, 8:11am
3
The LAN subnet is 10.16.0.0/24; in the RFC1918 Class ‘A’ block.
The output is too long to post, it exceeds the 40k char limit.
Plex Media Server Logs_2019-09-23_01-06-43.zip (1.6 MB)
[/details]
ChuckPa
September 23, 2019, 5:07pm
4
Thank you for attaching the log ZIP as I had requested. I know the forum would not accommodate what was needed.
From your logs:
Sep 22, 2019 19:56:39.048 [0x7f7aff7fe700] ERROR - getaddrinfo(10-16-0-69.abcdefghijklmnopqrstuvwxyz012345.plex.direct) failed: -2
DNS rebinding protection is blocking the detection
Sep 22, 2019 19:56:39.035 [0x7f7a77fff700] DEBUG - HTTP requesting GET https://67-176-122-120.9cbbd6209ae24d20a58fdf95abc68277.plex.direct:26495/security/token?type=delegation&scope=all&X-Plex-Token=xxxxxxxxxxxxxxxxxxxx
Sep 22, 2019 19:56:39.047 [0x7f7aff7fe700] DEBUG - EventSource: Read HTTP reply header.
Sep 22, 2019 19:56:39.047 [0x7f7aff7fe700] DEBUG - MyPlex: We appear to have regained Internet connectivity.
Sep 22, 2019 19:56:39.048 [0x7f7aff7fe700] DEBUG - Network: 10-16-0-69.abcdefghijklmnopqrstuvwxyz012345.plex.direct failed to resolve to 10.16.0.69 but instead yielded ""
Your choices are:
Turn off DNS Rebinding Protection (not ideal)
Create an exception / Declare the Private Domain plex.direct in your DNS resolver.
Declaring a private domain exemption on pfSense is
server:
private-domain: "plex.direct"
Additionally, if the server computer is running any kind of firewall, verify the following ports are open as defined here:
https://support.plex.tv/articles/201543147-what-network-ports-do-i-need-to-allow-through-my-firewall/
divzero
September 23, 2019, 6:11pm
5
There is a firewall rule to allow Plex traffic.
As it turns out, I am on pfSense, I’ll set that exemption and try again.
ChuckPa
September 23, 2019, 6:26pm
6
Add it to the DNS Resolver.
system
Closed
December 22, 2019, 6:38pm
7
