Plex Relay Not Working
A fix is being worked on to allow Relay to be used when ipv6 is enabled.
Meanwhile - stick with ipv6 disabled within Plex Media Server advanced network settings
Plex Media Server 1.14.1.5487 has just been released as Beta. It has fix for the issue of Plex Relay failing when ipv6 is enabled
See Release Notice
  • (Relay) The relay service may not function when server support for IPv6 is enabled on some systems (‪#9399‬)
Do you want me to test it? I’m currently running the non-beta version.
It should work. But yes - please do try it. We should now be listening on 32401 for 127.0.0.1 when ipv6 is enabled. We were not before
It works now even with ipv6 enabled.
