Yesterday i updated server but after reboot my server was gone… had to tunnel into localhost and setup port/ssl & network… had medialibrary saved, but every user now have 2 servers on their accounts… a offline and a online…
any advise on why this happens?? it did once before a couple of month back…
Is the path on a fixed internal disk ? is it a mounted volume?
It should only create a new Preferences.xml if there was not one there to start with. If one existed and contained the MachineIdentifier and ProcessedMachineIdentifier fields then it would be using those and not generating a new machine identifier
