@dylan8108 said:
I am having similar issues with my plex server saying “server unavailable” about once a month or so and the only way i found to fix it is to delete plex plugin on FreeNAS then add it back and set everything back up again then good for another few months… Maybe
unlikely to be the same issue was what is in this thread for a problem that was 2 years ago
As this is not even a Western Digital NAS which is the forum this thread is in, i suggest you raise a new topic in the FreeBSD forum which is the closest for your plex media server environment
http://forums.plex.tv/categories/freebsd
But please only do that when the problem arises and you are in a position to attach a zip of the Plex Media Server logs to your post. Please also indicate time of error
Run with debug logging enabled - before problem arises
See https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
and capture the logs when it does
https://support.plex.tv/articles/200250417-plex-media-server-log-files/
See this support article for location of logs https://support.plex.tv/articles/202915258-where-is-the-plex-media-server-data-directory-located/
