has anyone else noticed since the last update on Nvidia Shield that the plex server now goes to sleep when you put the shield to sleep. Hoping there’s just a setting I’ve missed.
I don’t think that’s what’s happening to the shield. I’m pretty darn sure that I have been able to access my Plex server after putting shield to sleep… BUT something keeps occurring overnight perhaps during the butler processes that is causing it to become unavailable where nothing will connect to it, until you force close it and then start it up (sometimes you have to try multiple times).
Are you positive it’s tied to the sleep state of your shield?
Yeah I used to be able to still access it but after the update as soon as I sleep shield the server cuts off
I just force closed and restarted the server on my Shield (because it died overnight), the Shield is currently “sleeping” and I’m able to connect and browse to it. At least in my case, this isn’t happening… it’s something it’s doing overnight that is killing mine.
That’s odd. Thank you for checking. Appreciate it
Hi, I have same issue, if you will find a solution,please, update me, same if I will fins somothing. Thanks.
Will do. So far can’t see anything to fix it.
Think there is an issue with that update as my server has been disconnecting all night.
