(SOLVED) Playback Error - Could Not Tune Channel
Server Version#: 1.25.5.5492
Player Version#: 4.75.0
Tuner Make/Model: HDHomeRun Connect Duo
Guide/Lineup name:
Using XMLTV?: No
Channel number/Name: WNYT 13.1 (NBC)
I haven’t been using the Live TV/DVR feature in some time, but decided to revisit this feature recently. I am unable to view any live TV broadcast on my Plex Media (Mint Linux 20.2 ) Server nor can I view live TV on any of my connected devices.
The HDHomerun Connect Duo & server are on the same network. I updated my OS, Plex and the HDHomerun Connect to the latest software versions. I have read through similar posts but have not been able to resolve the issue. I have scanned the logs, but I do not see an obvious issue. I would truly appreciate any help. I have included my logs. I restarted the server and then recreated the issue in hopes of keeping the logs short.
Plex Media Server Logs_2022-02-19_14-45-45.zip (1.4 MB)
Need to repair your database: Repair a Corrupted Database | Plex Support
Feb 19, 2022 14:44:40.063 [0x7f61f46bab38] DEBUG - [DatabaseFixups] Running fix-ups.
Feb 19, 2022 14:44:40.063 [0x7f61f46bab38] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, database corruption at line 67007 of [1b256d97b5]
Feb 19, 2022 14:44:40.063 [0x7f61f46bab38] ERROR - [DatabaseFixups] SQLITE3:0x80000001, 11, statement aborts at 2: [select count(*) from metadata_items] database disk image is malformed
Feb 19, 2022 14:44:40.064 [0x7f61f46bab38] ERROR - [DatabaseFixups] Fixup 42DatabaseFixupsGarbageCollectTransientItems threw an exception: sqlite3_statement_backend::loadOne: database disk image is malformed
Wow. that did it! Thank you so much! I learned something new today.
