Plex server not detected even though running
Server Version#:plexmediaserver_1.25.1.5286-34f965be8_amd64
Player Version#: N/A
I do not know what is wrong and have been trying to figure it out for a few days now. I am stumped. I updated to the current version of plex for ubuntu and now I cannot see my server even though it is running. I have purged and reinstalled the software and still no luck. below is the status of my system and it shows plex running. But when I log into the web interface. I see everything but my libraries of movies and it does not display my server at all.
rick@rick-M52BC-M32BC:~$ sudo service plexmediaserver status
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2021-12-02 07:51:59 EST; 10min ago
Process: 10310 ExecStartPre=/bin/sh -c /usr/bin/test -d “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” || /bin/mkdir -p “${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}” (code=exited, status=0/SUCCESS)
Main PID: 10312 (Plex Media Serv)
Tasks: 54 (limit: 38265)
Memory: 84.5M
CPU: 8.145s
CGroup: /system.slice/plexmediaserver.service
├─10312 /usr/lib/plexmediaserver/Plex Media Server
├─10334 Plex Plug-in [com.plexapp.system] /usr/lib/plexmediaserver/Resources/Plug-ins-34f965be8/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.1.5286-34f965be8 /us>
├─10373 /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.25.1.5286-34f965be8 32600
└─10421 Plex Plug-in [com.plexapp.agents.imdb] /usr/lib/plexmediaserver/Resources/Plug-ins-34f965be8/Framework.bundle/Contents/Resources/Versions/2/Python/bootstrap.py --server-version 1.25.1.5286-34f965be>
Dec 02 07:51:59 rick-M52BC-M32BC systemd[1]: Starting Plex Media Server…
Dec 02 07:51:59 rick-M52BC-M32BC systemd[1]: Started Plex Media Server.
@rwseitz0654
  1. Upper right corner of the Plex/web browser – SIGN OUT
  2. Close the browser
  3. Open the browser fresh
  4. Open an incognito window
  5. In that incognito window - http://127.0.0.1:32400/web (assuming you’re running from the same Ubuntu computer where the server is running)
  6. It will load the Plex/web app and want you to sign in.
  7. Sign in and click the “Got It”.
  8. The setup wizard will start.
OK tried all that. It is still not recognizing my server. Which is the computer I am working on. A message pops up and says something went wrong on their end. Then it just sits there with the little cursor spinning.
