Plex server not starting on reboot iMac after OS update to Ventura 13
Server Version#:1.31.0.6654
Player Version#:1.31…0.6654
After a OS update to Ventura my Plex sever doesn’t startup in the background, did be for have to start in manually now, and then works fine. I updated my Plex server around the same time.
Cheers
Colin
Might be related to Mac’s security. I had a problem adding media folders that this link solved & it might be the reason that the startup setting isn’t saving.
On the Mac, in settings > privacy & security > full disk access. Here, add the Plex Media Server app.
Thanks - that fixed it.
Thank you
Well it did work but I have restarted my iMac today and the Plex server isn’t running again. I checked the setting to sent and made sure I still have Plex tuned on in the Full Disk Access, Strange, any other ideas??
Colin
