Server Version#: 1.20.3.3437
Player Version#: 1.18.0.1913 and Web version
My UNRAID CACHE drive died and since then my PLEX server is not working correctly.
All my libraries seem to have gone or at least are not linked, the a-f folders are there, but if I try to re-add or reconstruct the libraries I just get a failure that states
"There was an unexpected error
Please visit our forums if you continue to experience problems"
Any ideas on what to do?
Having looked at the log I see this
INFO - Plex Media Server v1.20.3.3437-f1f08d65b - unknown PC unknown - build: linux-x86_64 redhat - GMT 01:00
Apr 28, 2021 15:24:50.580 [0x149ed55d9640] INFO - Linux version: 5.10.21-Unraid (#1 SMP Sun Mar 7 13:39:02 PST 2021), language: en-GB
Apr 28, 2021 15:24:50.580 [0x149ed55d9640] INFO - Processor Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
Apr 28, 2021 15:24:50.581 [0x149ed55d9640] INFO - /usr/lib/plexmediaserver/Plex Media Server
Apr 28, 2021 15:21:46.329 [0x149e33bfd640] DEBUG - Asked for unknown type: 2021
The last line just repeats
Anyone any ideas?
Are you not backing up your appdata folder or running a protected cache pool? You probably have to remove all the old data and rebuild from scratch if you don’t have a backup to restore from.
who’s docker are you using?
if you were running your appdata on your cache drive you have lost everything need to start over and restore a backup
