Server Version#: 1.22.2.4282
Player Version#: 4.54.5
My windows plex server will only show up as a remote connection on my local devices. I have checked the ip’s and subnets are the same for each device, disabled the pc antivirus and firewalls, disabled the router firewall and completely removed and reinstalled plex media server. But now im out of ideas and hope someone has a suggestion i can try
I think my router is the issue but im not sure what needs changing, the router im using is the bt smart hub 2 if it helps
