Plex Server shows as Offline for friends
Server Version#:
Environment
  • OS: Windows 11 (fully updated)
  • Plex Media Server version: 1.41.8.9834-071366d65
  • Server type: Windows desktop/server install
  • Remote Access: Enabled, port 32400 forwarded, shows Fully accessible outside your network
  • Networking:
    • Public IP (not behind CGNAT)
    • LAN Networks set to 192.168.3.0/24
  • Issue:
    • Friends always see the server as offline, even when on my LAN.
    • Plex.tv does not show error messages — the server simply appears offline for others.
    • Attempting to change or manage user sharing → “There was an unexpected error.”
    • After reinstall/re-claim, it worked for ~12 hours, then stopped completely. Now friends can’t access at all.
What I’ve Tried:
  • Verified not behind CGNAT.
  • Verified remote access is green and working for my account.
  • Verified only one server exists under Account → Devices (no ghost servers).
  • Unshared and re-invited users via Plex Web. Initially works, then fails after ~12 hours.
  • Enabled “Enable Relay”.
  • Set Preferred Network Interface = Any.
  • Set LAN Networks = 192.168.3.0/24.
  • Set Custom Server Access URLs = http://192.168.3.192:32400,http://:32400.
  • Confirmed Windows Firewall rules are allowing Plex Media Server on TCP 32400 inbound/outbound.
  • Deleted “Plug-in Support” and “Cache” folders → forced rebuild.
  • Fully uninstalled/reinstalled PMS and restored Metadata + Databases. Still fails after ~12–20 hours.
Current Behavior:
  • I (the owner) can always access the server locally/remotely.
  • Plex.tv shows the server as claimed, but friends never see it online.
  • Sharing libraries fails with “unexpected error”.
  • Friends cannot connect or stream at any time.
Update PMS. See Plex Media Server - Security Update - #3 by PlexInfo.
Just did that, now I can’t even access Plex locally.
Exact same issue here, tried all of the same troubleshooting to no avail.
Only difference is mine shows “not authorized” for friends but I can still access locally and remotely.
Same issue here. Updated to the latest update, no change
Mine is giving me a lot of problems outside of my network now as well. Just started for no reason I can tell. Hopefully someone comes up with a solution.
Also, I’m still having trouble outside my network even after updating to the newest version: v.1.42.1.10060-4e8b05daf
August 11, 2025
This is their solution to the security breach. Don’t fix the problem just break it.
