Plex Server Stops Responding But Process Still Running?
Server Version#: 1.28.0.5998
Player Version#: 4.84.1
PMS running on an 11th gen i7 NUC. Recently migrated install over from an older PC. Used the directions here to the letter. No issues after migration. The issue popped up a few versions ago. I had a hard time installing the upgrade because it kept telling me there was an upgrade even though the version numbers were the same. I had to do a manual install to correct that. The last info in the server logs just before the server stops responding looks like this:
Jul 27, 2022 13:20:23.606 [2108] DEBUG - Request: [192.168.50.223:35774 (Subnet)] GET /library/onDeck (226 live) #1d3212 GZIP Signed-in Token () / Accept => application/json / Accept-Charset => UTF-8 / Accept-Encoding => gzip / Connection => Keep-Alive / Content-Length => 0 / Host => 192.168.50.15:32400 / User-Agent => Ktor client / X-Plex-Client-Identifier => testPlexAndroidTVHelperApp123456789 / X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 27, 2022 13:20:23.607 [2108] DEBUG - Completed: [192.168.50.223:35774] 401 GET /library/onDeck (226 live) GZIP 0ms 357 bytes
Jul 27, 2022 13:20:23.607 [31920] VERBOSE - Comparing request from 192.168.50.223 against 192.168.50.15/255.255.255.255
Jul 27, 2022 13:20:23.607 [31920] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 27, 2022 13:20:23.607 [31920] VERBOSE - Auth: tokens were refreshed recently enough
Jul 27, 2022 13:20:23.607 [31920] DEBUG - Auth: authenticating user as guest
Jul 27, 2022 13:20:23.607 [31920] DEBUG - Request: [192.168.50.223:35776 (Subnet)] GET /library/onDeck (226 live) #1d3214 GZIP Signed-in Token () / Accept => application/json / Accept-Charset => UTF-8 / Accept-Encoding => gzip / Connection => Keep-Alive / Content-Length => 0 / Host => 192.168.50.15:32400 / User-Agent => Ktor client / X-Plex-Client-Identifier => testPlexAndroidTVHelperApp123456789 / X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 27, 2022 13:20:23.607 [2108] DEBUG - Completed: [192.168.50.223:35776] 401 GET /library/onDeck (225 live) GZIP 0ms 357 bytes
Jul 27, 2022 13:20:23.664 [31920] VERBOSE - Comparing request from 192.168.50.223 against 192.168.50.15/255.255.255.255
Jul 27, 2022 13:20:23.664 [31920] VERBOSE - Auth: We found auth token (xxxxxxxxxxxxxxxxxxxx), enabling token-based authentication.
Jul 27, 2022 13:20:23.664 [31920] VERBOSE - Auth: tokens were refreshed recently enough
Jul 27, 2022 13:20:23.664 [31920] DEBUG - Auth: authenticating user as guest
Jul 27, 2022 13:20:23.664 [31920] DEBUG - Request: [192.168.50.223:35778 (Subnet)] GET /library/sections (226 live) #1d3215 GZIP Signed-in Token () / Accept => application/json / Accept-Charset => UTF-8 / Accept-Encoding => gzip / Connection => Keep-Alive / Content-Length => 0 / Host => 192.168.50.15:32400 / User-Agent => Ktor client / X-Plex-Client-Identifier => testPlexAndroidTVHelperApp123456789 / X-Plex-Token => xxxxxxxxxxxxxxxxxxxx
Jul 27, 2022 13:20:23.664 [2108] DEBUG - Completed: [192.168.50.223:35778] 401 GET /library/sections (226 live) GZIP 0ms 357 bytes
Jul 27, 2022 13:20:24.176 [24212] DEBUG - Ordered to stop server.
Jul 27, 2022 13:20:24.176 [39076] DEBUG - Stopping server...
Those same or similar entries had been repeating over and over for at least ten minutes before the server stopped responding. This seems to crash about every 12 hours or so.
Sounds like the deadlock issue that has been affecting multiple people. See this thread here: Plex Server Crashing Randomly - #78 by brucestephensrx
Looks like the deadlock issue we are investigating. An alpha 1.28.1 build is being tried by a number of users. I see that you are now on the 64-bit windows forum preview release which is also on 1.28.1 - so hopefully that will fix the problem - if not, we will need to get deadlock diagnostics which you can find in the linked topic or can be explained when seeing full debug server logs of the issue on 1.28.1
Will this 1.28.1 version be available for Windows beta users ?
Plex is crashing every day with the current version.
If you want to verify you have the same issue, take a look at this post and PM the diagnostic info to @sa2000 so he can add you to test builds:
Please Media Server 1.28.2 has just been released as a beta release
It has a fix for a deadlocks issue that was identified last week
  • Server could hang in certain circumstances (#13758)
