Plex Server stops running every few days
Hey Everyone,
So, I have this odd issue that I’ve never had before. The only change I’ve made is I switched to an XMLTV guide using zap2xml docker on Synology a few weeks ago. I was annoyed with the continued episode number problems I was having with the stock guide. Anyway that’s a separate issue, since then, Plex will stop running. The size of the XML file is between 130mb and 140mb depending on the day. It updates every 12 hours. So, I’m thinking either it’s having a problem digesting the file occasionally OR the script is writing out the XML file while the Plex is doing a guide update causing a crash. I can’t seem to figure out how to only update Plex AFTER the XML File is updated. Anyone have any ideas? Thanks in advance.
Running PMS 1.19.5.3112.
Mike
