Plex server unclaimed after every reboot
Yes, latest BIOS installed (dated 14 Mar 2023)
stupid question time;
  1. UEFI boot
  2. dedicated UEFI partition on HDD ?
e.g.
[chuck@lizum ~.2003]$ sudo parted /dev/nvme0n1
GNU Parted 3.3
Using /dev/nvme0n1
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: Samsung SSD 970 PRO 1TB (nvme)
Disk /dev/nvme0n1: 1024GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name                  Flags
 1      1049kB  524MB   523MB   fat16           EFI System Partition  boot, esp
 2      524MB   132GB   131GB   xfs             root
 3      132GB   196GB   64.0GB  linux-swap(v1)  swap                  swap
 4      196GB   1024GB  829GB   xfs             home
(parted)
To my understanding yes
Dell
at some point.
(this WILL scare you)
sudo systemctl enable fstrim
sudo systemctl start fstrim
It force releases the unused pages in the SSD.
On my 1TB, it takes about 15 seconds of blistering SSD activity and the system otherwise frozen. (nothing gets lost – the SSD is that busy)
The benefit is SSD wear leveling. All i/o will be improved.
[chuck@lizum Databases.2036]$ date;sudo systemctl start fstrim; date
Fri 07 Apr 2023 05:38:32 PM EDT
Fri 07 Apr 2023 05:38:47 PM EDT
[chuck@lizum Databases.2037]$
Thanks a lot - I had not really thought about Trim for this machine. On my Windows machines this is set up as an automatically recurring task
Took less than 2s on my server (smaller drive and almost empty)
