Plex server update and interface go white background
Server Version#:1.40.2.8273
Today upgrade server version from Synology , and dashboard (webUI) have white background.
I try with different browsers (edge, chrome, opera) with normal mode or private mode.
I try restart server… no change…
I try reinstall same version (don’t work)
Thanks for any help…
Are you on MacOS, Windows or some flavor of linux?
does https://app.plex.tv do the same as the local?
Try in linux opera and linux chrome…
across app.plex.tv , interface is ok
Can you empty your browser cache and hard reload?
Yes, i try clear cache and use private mode… and open dev tools in browser and activated option “Disable Cache”
With upgrade opera/chrome, WEBui it’s normal.
