White background on PMS after update on Safari
I saw this issue once before so I held off from updating, but after updating the Plex Media Server from version 1.32.3.7162 to version 1.32.5.7516 I now have a white background when viewing the server on Safari 13.1.2 on Mac OSX High Sierra. All of the icons are clickable, artwork is the normal color, but because some text is white or gray, it makes it extremely difficult to see buttons or text. I don’t however have this issue if I open the server in Firefox ESR. This only seemed to happen on versions newer than 1.32.3.7162. I’m well aware that High Sierra is pretty much on life support as far as compatibility goes, but I’m curious if anyone else has seen this and has found a way around this on Safari?
Server Version#: 1.32.5.7516
Plex Web Version#: 4.108.0
Can you take a screenshot of what it looks like
I’m have this white background problem. Makes it hard to see menus is there a fix
Do you get the same the local web app at local IP and the one https://app.plex.tv ?
