I’ve been running Plex on an Ubuntu server for many years with only minor issues. Today I can’t get Plex to start at all and the service is failing. I’m a Linux novice so troubleshooting it is not easy for me. I’ve tried reinstalling it a few times but still no luck. I always keep everything running the latest updates, so I’m the latest version of everything. One thing of note is that I have been having to do a manual fsck a few times recently on my SSD when rebooting for some reason, and I had to do that today when starting the machine. Since where I normally run this doesn’t have a monitor, when I troubleshoot it I run it from my desk and the main change is that I then use wifi instead of the normal eithernet cable. Doubt that matters and I’ve run Plex this way before, but just adding all the variables.
Below is the result of sudo journalctl -xe | grep -i plex
Jul 22 12:40:56 peter-nuc sudo[5510]: peter : TTY=pts/0 ; PWD=/etc/systemd/system ; USER=root ; COMMAND=/usr/sbin/service plexmediaserver start
Jul 22 12:40:57 peter-nuc systemd[1]: Starting Plex Media Server...
-- Subject: A start job for unit plexmediaserver.service has begun execution
-- A start job for unit plexmediaserver.service has begun execution.
Jul 22 12:40:57 peter-nuc systemd[1]: Started Plex Media Server.
-- Subject: A start job for unit plexmediaserver.service has finished successfully
-- A start job for unit plexmediaserver.service has finished successfully.
Jul 22 12:40:57 peter-nuc systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=255/EXCEPTION
-- An ExecStart= process belonging to unit plexmediaserver.service has exited.
Jul 22 12:40:57 peter-nuc systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
-- The unit plexmediaserver.service has entered the 'failed' state with result 'exit-code'.
Jul 22 12:41:02 peter-nuc systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 1.
-- Automatic restarting of the unit plexmediaserver.service has been scheduled, as the result for
Jul 22 12:41:02 peter-nuc systemd[1]: Stopped Plex Media Server.
-- Subject: A stop job for unit plexmediaserver.service has finished
-- A stop job for unit plexmediaserver.service has finished.
Jul 22 12:41:02 peter-nuc systemd[1]: Starting Plex Media Server...
Jul 22 12:41:02 peter-nuc systemd[1]: Started Plex Media Server.
Jul 22 12:41:02 peter-nuc systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=255/EXCEPTION
Jul 22 12:41:02 peter-nuc systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Jul 22 12:41:08 peter-nuc systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 2.
Jul 22 12:41:08 peter-nuc systemd[1]: Stopped Plex Media Server.
Jul 22 12:41:08 peter-nuc systemd[1]: Starting Plex Media Server...
Jul 22 12:41:08 peter-nuc systemd[1]: Started Plex Media Server.
Jul 22 12:41:08 peter-nuc systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=255/EXCEPTION
Jul 22 12:41:08 peter-nuc systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Jul 22 12:41:13 peter-nuc systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
Jul 22 12:41:13 peter-nuc systemd[1]: Stopped Plex Media Server.
Jul 22 12:41:13 peter-nuc systemd[1]: plexmediaserver.service: Start request repeated too quickly.
Jul 22 12:41:13 peter-nuc systemd[1]: plexmediaserver.service: Failed with result 'exit-code'.
Jul 22 12:41:13 peter-nuc systemd[1]: Failed to start Plex Media Server.
-- Subject: A start job for unit plexmediaserver.service has failed
-- A start job for unit plexmediaserver.service has finished with a failure.
