Hello, I have been successfully running plex on my Ubuntu 18.04 server for a couple months now, and yesterday it went down without any apparent reason. I tried rebooting, turning off all of the other services on my machine, reinstalling (and moving the old /var/lib/plexmediaserver to another directory to make sure it stars with a clean slate) and nothing seemed to resolve the issue. I am using plexmediaserver_1.13.4.5271-200287a06_amd64.deb (I’m a plexpass user). Attached are the logs (tar’ed up /var/lib/plexmediaserver/Library/Application Support/Logs/*) , please help!
PMS is starting.
You do have 3 adapters defined (which can confuse PMS but is about to be resolved in PMS 1.13.5 update with the ability to select which adapter to listen to)
When I disabled docker everything worked, but as soon as I re-enable docker plex stops working. Do you have an ETA on when 1.13.5 will get released (or is there a beta channel I can subscribe to)?
