Plex stopped working suddenly on my LG TV
Hello, I will be glad to assist you, but I suspect your command is valid for Linux, not for Windows. If you provide me with a step-by-step tutorial, I will try to send you the information you need. Also, the router-ip is the local one?
I’m sure it has been due to a change in plex, https issues surely, it has already happened on other occasions and you have solved it, I imagine that by enabling or allowing some connections in some way, the tvs are not updated nor the apps either, in my case I do not update even the plex server to avoid any problem. That’s why I know for sure that the problem is something on the plex platform, which has to do with the authentic ion or something.
Thank you very much for everything, I hope you can fix it soon. Thank you and best regards
I pushed a possible fix.
Could one of you tell me if it fixed the problem ?
If not I’ll need more time to find a pcap internally to investigate.
That did it. No issues connecting to the server now. Many thanks - appreciate these TVs are slightly old but thanks for continuing to support them so we don’t have to add to a landfill.
Great! It is working again! Thank you very much for fixing it.
Thank you very much! Thanks for continuing to allow us to use plex on our old TVs.
Best regards
Thank you so very much you have made me a very happy user!!!
