Plex Streaming Lag Issue
Server Version#: 4.110.1
Player Version#: Not Sure
I recently had a terrible lag issue which forced me to Uninstall plex from my pc and then reinstall it altogether. It solved the issue and has been working fine for about 3 weeks. Then, the problem started happening again. I tried Uninstalling and reinstalling the plex server on my pc but the problem persists.
Basically it struggles to load the movie and when it finally does, it starts to lag a bunch. My wifi connection is about 160mbps and I am using a roku device to connect. I am sing a 4800x Roku Ultra downstairs which has worked perfectly fine for the most party for 2 years and a 3810X Roku Stick in our bedroom, also been working fine for 2 years. Both systems are now having the exact same issue.
Does anyone have any ideas on how else to fix this?
