Plex streaming shows three dots on TiVos
All three TiVos (Bolt, Roamio, and Mini) showing the three dot buffering indicator when trying to stream from NetGear ReadyNAS - upgraded to the latest server software - no change. Home screen works, browsing works - just actual streaming broken.
Any suggestions welcome.
Instructions for putting this post in a more appropriate location also welcome.
Thanks in advance.
I am having the exact same issue. Two TiVo Bolts and many TiVo Minis all experiencing the same ability to connect and browse but not stream. I too have upgraded the server and restarted all components but I still cannot stream. I wonder if this is a certificate issue?
Yep, it is a cert issue. I changed SETTINGS > NETWORK > SECURE CONNECTIONS > DISABLED and that fixed it.
Over here if I set the Plex network security to Preferred, and setting my Tivo Edge to allow insecure connections it doesn’t work. Tivo mini’s continue to function. Setting Plex Network Security to Disabled will allow the Tivo edge to work again; however you can not access your plex outside of your home through app.plex.tv; minis continue to work no matter what.
That worked for me. Thanks.
worked for me as well
How do you perform these steps with the Tivo Roamio? I don’t see the Secure Connection
Option.
